Windsor64
Hi everybody, I would like to upgrade my 35 A alternator to 60 A and convert my ammeter to voltmeter, what are the best places for this conversion ?
Thanks Alain
Thanks Alain
Thanks Alain
Oh no!! The dangerous ammeter!!This is what I want to do while removing the dangerous ammeter.
Well said!!Oh no!! The dangerous ammeter!!
The ammeter kidnapped the Lindberg baby!!
Thanks Alain
My 66 has electric fans, a 540 watt stereo and fuel injection.The wiring for the charge circuit on your car is designed for a 35 amp alternator. The wiring gets brittle with age. It would be helpful to know if the car in question is a '64 Windsor.
Switching to a 60 amp alternator without upgrading all of the wiring in the charge circuit is more dangerous than the stock ammeter. This is also a swap that creates a domino effect.
If this is what you want to do, you at least need to:
- Upgrade all of the wiring in the charge circuit
- Do an ammeter gauge bypass (search this site for details)
- Upgrade to the '70 & up voltage regulator or use this one;
Mopar Voltage Regulator - Electronic Solid State with Correct Restoration Look | eBay
- Clean and check all of the bulkhead connectors
- Run separate wiring for your voltmeter
A headlamp relay conversion would also be beneficial.
Why not just go with a 45 or 50 amp alternator?
Why do you feel that you need the 60 amp alternator? Unless you are running electric fans or a power draining mega watt stereo system or fuel injection you should not need a 60 amp alternator.
Does anyone have anymore info on the needle that was glued on in the ammeter to volt meter gauge? I have everything needed to complete this but have some concerns about longevity and cutting the needle off the volt gauge to glue one on from a donor cluster. Was this glued over top of the needle or was it actually cut and glued end to end?Redline Gauge Works would be the most professional route.
Redline Gauge Works Refurbs A Retro Chrysler Cluster - Mopar Connection Magazine | A comprehensive daily resource for Mopar enthusiast news, features and the latest Mopar tech
Or you can try to do it yourself.
Gallery: How to Convert an Ammeter to a Voltmeter on the Cheap - Mopar Connection Magazine | A comprehensive daily resource for Mopar enthusiast news, features and the latest Mopar tech
Thanks for reply. Yeah I would like to see what yours looks like and know more details on how you completed it. I like the idea of having the factory appearance but I am hesitance to cut the needle off my factory gauge to glue it to the volt meter. I would hate for the thing to fall off then have to figure out and alternative.In my 67 Newport, I converted my ammeter to a voltmeter by removing the ammeter from the dashboard, gutting it and replacing the guts with a digital voltmeter of the correct dimensions that I found on ebay. I then cut a hole in the ammeter meter scale so the voltmeter would be centered on the scale and put the whole thing back in the car. I then connected the voltmeter wiring to the appropriate place and connected the ammeter wires together. to complete the circuit. The comments about the bulkhead connector and grounds are very much on point. In my car I also had a fuse box with not one good connection in it, so I had to replace that as well. If you want more details on the voltmeter I can provide
