Another Disc brake question.
It was the practice to include a power booster with any front disc brake car in the 1960s and later. EXCEPT for 1970 Camaros which could have non-power brake front discs.
A minor correction: Mopar made manual-disc A bodies in the late ‘60s.
Good morning, all. I'm considering doing a Scarebird front disc brake conversion on my 68 Newport. I have recently, within the last two years had my brake booster rebuilt,
(booster Dewey). It has less than 1k miles on it.
My question is...is it absolutely necessary to use a disc brake booster for this conversion? Has anyone used a drum brake booster with disc brake set up with success?
TIA. Appreciate all suggestions and opinions.
1965-72 Plymouth, Dodge C-Body full size front disc
I had this done to my 69 Newport convertible
Replaced the master cylinder with a new one. Added a disc booster pump with a proportional valve. Works great and has no problem stopping this beautiful work of art.
Smaller body platforms might have been good with non-power front disc brakes, as most import cars were. The manual disc brakes cars might have been around, but probably not many, I suspect. I know what it takes to stop my '77 Camaro with power front disc brakes. I would not want to consider what it might be with non-power front disc brakes, although they were available.
My other gut suspicion is that IF a dealer ordered an A-body with non-power front disc brakes, for whatever reason, they didn't order any more of them.
If I were you, I’d get the dual-diaphragm booster. If I were me, I’d keep using the original drum master, as I still am, on my ‘66 300 that I converted to ‘72 C-body discs, in the ‘80s.
Like any good boy scout.
I had manual 4 piston discs on my Dart. They worked fine. No extreme effort required.
I upgraded to the single piston style as rotors for the KH were not easily found. They worked great as well.
I have manual disc on my 300. feels similar to manual drums except linear modulation.
Thanks for that information. I'm glad you are pleased with the performance.
I just realized that I mistyped this comment. I did not use the original master. I put on a new ‘72 disc master and used the ‘72 New Yorker proportioning valve with new lines, plumbing it correctly for the dual system. What I did reuse was the drum booster. It has always worked just fine.
When you did your conversion, was there a noticeable difference? Do you feel it was worth the effort? Dual diaphragm boosters seem to be out of stock at the moment. Not in a rush to get this accomplished, just gathering information. Thx.
