commando1
It's the one I have. Works 100%. And in 20+ years, you be giving it to someone who never had points before. lol
The Admiral has logged over 7K miles in the past 12 months pulling a 3200# trailer.
If it's a big block...An extra set of points is easy [for]... a quick repair if needed.
I guess there are exceptions here and there ....but im glad i did it..no more burned or pitted points.
Gotcha. I deep sixed that part with the points.burned/pitted points indicate a mismatched condenser. It's why I never mess with the condenser if my points don't show excessive pitting or buildup. Making sure the point contacts are properly aligned is important also.
But it will kill your battery, hope it's a stick so you can push start it4.) EMP, whether from the Forces of Darkness or solar flares won't destroy a breaker point ignition system
My new to me 69 FuryIII uses points. Sure I could go out and spend 100 to 600+ dollars and end up with a MSD outfit but are points so bad? I have heard people saying the Mopar electronic ignition kit with distributor can fail and you should carry an extra box with you etc.
If my current distributor has no shaft play and in good condition it should be fine on a stock 440 shouldn't it? Or do they really run better with the upgrade? I had a 69 Cutlass years ago and sprung for an MSD box. I thought it ran better but who knows. Are there any reliability issues with the stock points setup? If not I could throw some money elsewhere on the car.
Damn, that would be one huge ugly mo-fo in an otherwise stock engine compartment. Nice concept but definitely not for me.thanks fatwagon for your thoughts on this. The other side of the coin I have heard and read is that since Mopar does not actually make them [spark control box] anymore many have been known to fail and recommend you have a spare at all times. I guess they are now all made god knows where and god knows towhat standard.
Some have also said forget Mopar ignition anything and get the GM HEI conversion.
Like this for example. But who knows what quality this is either.
BB Mopar Hei Eletronic Distributor Ready to Run Chrysler Kit Dodge 413 426 440 | eBay
