In one respect, I don't see the real issue with single-plane or dual-plane intakes making much difference with EFI of any kind. It doesn't seem to with carbs and all the latest EFIs are are carbs with fuel injectors for each throttle bore rather than having a float bowl to pull fuel out of via air velocity through a venturi. Even if it's an annular discharge version.
The whole reason behind the first single-plane Edlebrock Tarantula intakes was more even air flow to each cylinder. Pull from a common plenum area with a more direct route to the intake valve. Of course, with the shorter runners, they "tune" at a higher rpm than the longer runners of the dual-plane intake. So, in that respect, more equal cylinder a/f distribution, a single-plane might be better.
The Holley Z-Line intake was a single plant intake, but with a full plenum divider and the "resonating port" which connected #7 and #8, so #8 could also pull from "7 in order to compensate for #5 firing right before #7, using the same corner of the plenum. Again, so each cylinder would get closer to the same amount of a/f mixture on each intake stroke.
To me, it's the efficiency of the fuel/air mixing above the plenum that makes for power and economy of operation. If that happens with a carb or otherwise, the "wet flow" manifold will get the a/f mixture to the intake valve.
We tend to know how big of a carb works for what size and type of motor, but with EFI, we might tend to go ga-ga over "lbs/hr" of fuel and how many horses that'll feed. The earlier 4bbl EFIs were all usually about 900-1000cfm flow capacity. Who'd buy a carb that big for a generally street or HP-street motor? But that's just me. Seems like somebody has a 750cfm Self-Learn 4bbl EFI? Annular discharge venturis? Seems like I saw that somewhere a year or so ago?
The MPI kits have been around for a long time. Expensive. But that expense now seems a little better if you consider how much easier they might be to make happen than the latest Self-learn EFIs seem to be.
Seems like Electromotive was one of the first to combine EFI and timing control? Pricey, so many "normal" hot rodders didn't seem to worry about it.
So . . . guess I need to do more research before I spent that much money on EFI!
Take care,
