Dsertdog
Ok I admit it. Electrical messes aren't my forte' I'm also very nervous about melting or setting things on fire.
For the record, nothing on my '66 Polara is broken at this time. When I took the instrument clusters out to re-bulb them, I cleaned the ammeter terminals real good and reinstalled them.
Things seem to work very well but I think my alternator has weak diodes. So I'm having it rebuilt. I'm not planning on putting aftermarket devices on the car, so the factory output will be fine.
The quandry is this. Of all the threads I've seen explaining the bypass, etc, one post discussed running a shunt from the battery post on the alternator to the battery terminal without removing the ammeter wiring.
The post stated the ammeter would work slower but that the system would charge better and the car would still start if the ammeter malfunctioned.
The quote is from can critters thread...
@cbarge
After experiencing this first hand and rewiring dozens of other Mopars,just do it.
Run a 10 gauge wire from the BATT stud back of alternator to the BATT stud of the starter relay and at the relay end use a 12 gauge fusible link.
This takes away half the load from the ammeter gauge and will eliminate any nuclear meltdowns should the alternator or voltage regulator short out.
Also, if the ammeter gauge take a dump,the car will still run.
First, do these photos circle the correct terminals I should attach the wire to?
@cbarge
