70Tom
OK, this is my fourth time trying to post this. Let's see if it works today.
So, I'm having a difficulties with my body molding clips for my 70 SF. Once I put the clip in the hole, you have to put the center pin in it so the clip stays in place. Otherwise, if you install the molding on the clips without the pin, all the clips will just pull out of the body and stay on the molding. Problem is, I can't get any of the pins inserted. I've tried hammering them in lightly. Either the clip will break or the pin will only go in half way and then stop/get stuck. As these clips are rare as hen's teeth and I've already broken several getting the molding off, I don't want to keep breaking them.
Any suggestions? I was thinking of maybe putting them in hot water, but not sure if that would make a difference.
If anyone has re-installed these clips on their car, please let me know.
Here's a pic of a clip installed with the center pin in it (the circle in the middle).
