Brake drums
69NooYawker
Petrolia, ON
Anyone got ant recommendations for new drums? Have to replace the fronts, or get them turned. Big groove in the passenger side one.... should I be looking at machining them or just get new ones from Partsgeek?
Thanks for any help guys.
I would take them in and see if they can be turned. I had to replace one of my original drums and the new drum was thinner than the original after I had it turned.
You will want to start by having the drums checked by a competent auto parts that has the proper measuring tools. A quick check is that on the outer edge of the factory drums there is a beveled cut, if the groove looks deeper than the bevel, the drum is most likely junk. If you can turn the drums, it is a good idea to turn both of them by the same amount so that you will get even brake wear. You should then have the brake shoes arched to match however much oversize your drums are. Many of the replacement drums now available are of thinner construction and are not designed to be turned at a later date. It is also a good idea to check any replacement drum for out of round due to rough handling during shipment or other manufacturing defect. Reject any drum that is more than .010 out of round.
In order to get the correct drums, you'll need to know the width of the brake shoes. Aim for 11x3 shoes and matching drums. Some of the catalog listings are squirley as when I was looking for my '70 Monaco, some didn't claim to have 11x3 items, but the dimensions of the items said they did. Have to carefully sift it all out! They seem to be there, when they allegedly aren't. When we did the rear brakes on our '66 Newport, its first time, the drums were wide enough for 11x3s, so we put the in back there. That made 11x3 all the way around. It DID stop well, that way. Other options for the back were 11x2.75 and 11x2.5.
Raybestos and similar have brake drum listings in addition to brake shoes and such. Check rockauto for an idea of what's out there. The price of brake drums has increased of late, so shop around for the best part and price.
As with the brake pads, check the "edge code" on the linings on the brake shoes. Of the two letters, "C" to "F", aim for "FF" for the best performance, if possible.
Get one of the inside/outside micrometers to adjust the brake shoes with. It'll give you a better initial adjustment. Pretty slick how it works! You first adjust it to the brake drum's friction surface diameter, then adjust the shoes to the appropriate diameter to match.
For best results, go through a "break-in" period of no hard stops at first. Progressively do harder stops as mileage is accumulated. Like moderate decal from 45-25mph, a few in a row, if possible. Then let them cool overnight and do it again the next day. You should feel the increase in decal rate and performance as things progress. A few hard decels can be done later on, without harm. The time investment will be worth it.
Looks like we've picked up a couple of good guys here...:thumbsup:
One add-on... cutting drums evenly side to side and using matching drums from the same manufacturer (not one old one new) is a good way to avoid the brakes pulling at different temperatures. Differences in heat dissipation will make matched linings act like unmatched in some (uncommon) cases.
My front drums were too thin and one was warped when I did my brakes recently. I bought some new Raybestos Professional Grade ones from RockAuto (11 x 2.75) and they were only $33 each. They were pretty nice drums for the money.
Thank you for the very comprehensive replies guys. You have no idea how reassuring it is to come across such experience. Makes me much more confident.
Thanks again.
Just wanted to say thanks to those who pointed me in the direction of Nigel at National Moparts. A true gent, and unbeatable prices. Definitely recommend. N.O.S 11 x 3s and matching shoes, awesome service.
