mgm1986
This is just as much of a venting post as a it is me just trying to document the things I am doing to my brand new to me 300. I went through the brake system and replaced the master cylinder, front wheel cylinders, new springs and added self adjusters, which were missing in the front but not in the rear. So strange.
After an initial test drive something was still off and the car pulls to the left when braking. So I decided to have the drums turned even though they felt and looked okay. After pulling the front drums back off I realized they are not the same. It is baffling to me that someone would actually knowingly install different brake parts on the same car!
I ordered new drums and shoes and will hopefully, once and for all, have a working brake system. I would never sleep at night reassembling with different drums. And since new drums require new lug studs I will probably make the switch to Right Hand Threads on the drivers side.
I don't mind the drum brakes but it seems the cost to rebuild these is going to be half the cost of what it would have been to convert to front discs!
Vent over, I need a "brake"!
