First thing... Is the mechanical advance free? Can you turn the distributor rotor a little with your hand?
Second, you can't generate enough vacuum with your lungs to move the plate. I don't know the amount of negative pressure (vacuum) that you could make with your lungs, but to give you an idea, a young, healthy man might be able to generate 2 PSI positive pressure on a good day. More likely 1.5 PSI.. 2 PSI is equivalent to 4 inches of mercury.... 4"hg.
It takes 10"hg to move your vacuum advance 4 degrees. See where I'm going with this?? 10"hg is 4.9 PSI.
Third, the lack of vacuum advance won't cause this issue. Timing will... along with a bunch of other things.
Thanks for the reply Big John, wish you had been around at start of the thread.. anyway..
First, How much is "a little" when turning the rotor? I wish I had known to check the mechanical advance last night.. will do it next week when I'm at the car again.
Second, I absolutely follow your logic/science regarding lung power, but still wonder how hundreds of youtubers demonstrate this feat (of making the plate move) so effortlessly by sucking the advance vacuum hose and also by simply moving the plate by the same degree with their fingers. I'm now confused.
With the vacuum advance canister still affixed to the plate and dizzy body, I was still unable to budge the plate a hair even using a screw driver with leverage. And I don't know if my "lungs" can pull the kind of vacuum you're talking about.
How would you suggest I test the vacuum advance canister now that I have it off and sitting at home.. mityvac?
Third, My power loss under load/throttle is right from 1 single rpm.. lagging, weak acceleration, then sadly just peters off at 30mph.. that's at a gradual rate/lower rpms... it's when I get on the throttle at all that it "puffs out" with soft popping as if there is zero acceleration, and just air suck. I was just reading a little about mechanical advance and that seems to make much more sense as a cause.. or part of the cause.
So check and set timing first?
OK, what do you suspect are the "bunch of other things"?
I'd like to approach the issue(s) in a logical, methodical order, as I learn, so I'm not just throwing time and parts at everything unnecessarily. Thanks.
