Fratzog
Not that I'm aware of but the clocks look very similar. Not sure if they interchange.I believe Ben has the '69-71 design in mind. Did the '68 Monacos ever have a tach option from factory?
-Kurt
-Kurt
Just to clarify my Monaco has the vacuum gauge option on the console. Believe tach and clock were also options for the console. Since I have no intention of getting rid of the vacuum gauge a discrete tach in the clock location by the speedo would be nice.
Given that PremiumDashDecals' vinyl transfers for the clock face are all of $9.99, I'd much rather see them make a repop for the tach and work around that. Believe me, I have very little desire to replicate the C-body dash fonts in 3D...
-Kurt
Ok, I guess. I don't keep up with the ABE reproduction world. R-body power door lock knobs would be of more interest than ABE stuff.
I'm watching also.... looking forward to installing one when ready....watching for updates...
What exact measurement do you need?
I'm probably going to simplify that housing design, now that I know where everything has to sit. I was trying to make room on the bottom when I did this one (hence the gauge cutout), but I keep forgetting that the original had loads of space used to clear the original tach assembly and that I can build whatever I want in that direction.
The one concern I do have is that I'm starting to think the bezel opening for the tach is larger than the clock variant. The space for the needle's sweep doesn't appear to be as spacious given the dimensions I'm working with.
Does anyone here have an original tach bezel they can measure - and also provide a photo of? I'd like to verify the size of that bezel opening.
-Kurt
There is no separate part number for a Tach bezel. They used the same bezel regardless of Tach, oil , clock or nothing . As I recall, even the blank is a block off plate
