live4theking
- Joined
- Nov 24, 2014
- Messages
- 12,894
- Reaction score
- 9,082
I'm running Cooper Cobras on my 68 NYer. I've got almost 10k on them with no problems.
Here Frankie,the 69 Fury III with 22570r15 (27.4 O.D.) on 15x7 wheels.
Original size was 7.75-15 but had puny 20575r15 on him when we bought him.
Fills out the wheelwells nicely and rides like a dream..
View attachment 437984 View attachment 437985
Hope this helps.
If those rims are 7” wide 225/70x15 will fit very nicely and are even available at reasonable prices in a whitewall.
Hi Carsten,RWL tires were not available back in the 1968 model year.
You can probably ask for a Datenblatt in germany and ask the TÜV to put different tires in your paperwork.
You should ask your preferred TÜV station how to get the original type size tires into the paperwork
Carsten
yes, I am german, too.
Previous owner of your car was also a member on the german mopar-forum.de IIRC
Carsten
You can go 22570r15 and get white lettering in a BFG or Cooper Cobra.
Going from a 2.76 to 2.93 is not worth the effort, UNLESS you are very sensitive to speed, by observation. To me, not worth the effort and cost involved. 2.93s were usually on 318 Furys back then. 383s got 2.76s. Either one could have 3.23s.
The P225/70R-15 tire will have about 755revs/mile, which relates to the old G70-15 size (which it replaces). Which is also right at the same revs/mile as a P235/55R-17 tire, if that matters.
The rear axle ratio relates to speed of the engine vs wheel speed. The tire size comes into play as "the lever" which the rear axle turns. Longer lever, more road speed per engine rpm, and vice versa. Now, changing the tire size will NOT affect the readings (speed and distance) you see ont he speedometer, but will show a difference via GPS speed readings, where actual road speed is measured.
There are several tire size comparison "charts" on the Internet. The first one I found was at the Miata Club website. Later, I found the same thing in other places. You put in your starting tire size and then the second tire size. It will show a graphic of how much taller/wider one tire is than the other, plus speedometer error in percents.
The Chrysler TorqueFlite was used by a few foreign car manufacturers. Jensen was on (Jensen Interceptor) and Monteverdi was another one. You can look at tire sizes and speedometer gears (drive and driven) in the Chrysler Factory Service Manual, with tire sizes . . . it's the combination of rear axle ratio and tire size that matters.
I know, the rear end in question is from a 67 Fury with a 318. I absolutely don't care about speed. It's just a cruiser but at some point before export to Germany some idiot put a Chevy axle in there. Must have been around 2002. I didn't notice when I purchased it last year. The certificate even says it's matching numbers. So the whole thing was a fraud.
The diff sounds like a washing machine and needs revision anyway so now is the time to go back to an original 8,75". Since it's an urgent matter (car is also used commercially) and rear ends in Germany are rare, thats my only option right now. Or an 2,76 from a b-body which is a little shorter. Would that fit as well?
I checked a lot of charts before writing here but unfortunately none of them helped me regarding German laws.
Thanks a lot. I will check the other manufacturers as well.
Thanks for the confirmation.That sounds accurate. Hopefully the brake drums and associated equipment are in good repair on the 8.75 axle.
Next time I visit Deutschland I will have to buy you a Bitburger.
I don't really know. Basically I'm a big MCM fan in general (music, furniture, houses). But my weakness for old cars comes from being a film buff since I was a kid. I also love European and Asian cars mainly from 60s to 80s. We have a VW Golf I Convertible (You know it as VW Rabit), a Volvo 940 Turbo wagon and I always wanted to drive a V8 from the muscle era. I was very close to buying a B-body (had offers for a 69 Satellite and a 67 Coronet) but the budget forced me to move to a C-body. Unfortunately the seller was a rotten egg.Thank you for the suggestion!
Are all large American cars popular in Germany/ Europe now, or mainly Chrysler vehicles?
