Can you ID this AC compressor and brackets?
1970FuryConv
Richmond, VA
This is one of parts that I had because someone gave it to me. I pulled it out to see if it would donate a clutch for a 1973 SB V8. It would not. Then I thought, "What engine would this strange rear bracket attach to? My knowledge of AC being extremely limited. I thought I'd ask the experts.
3 prong pulley
Tapered/keyed input shaft
Unknown pulley on left, 1973 3-prong on right
Unknown pulley, clutch area much more shallow. Clutch is about half width of my 1973 clutch
Rear bracket: looks strange to me. What engine would this attach to?
BB mopar 1968 and older had that bracket that went across the front of the intake. I have a 1962 that has a clutch like that.
one head has the aluminum tag, look on the other head to see if there is a black painted tag held on with the head bolts, it will have a date stamped on it.
My 67 300 drop top has that engine compartment clogging nightmare. Now resting comfortably on a shelf in my garage. Good place.
Cam (shaft)
Definitely big block, B engine bracket would be a little shorter than RB engine.
Definitely looks like a 68 assembly, my Newport has factory A/C - the bracket here looks the same as mine. If you asked me, I can understand why they made it so firm, but at the same time, it does seem a bit excessive to have so many brackets...
I will look for the tag. Rusty unit. Legible, who knows? Thanks.
Hi Matt
Would casting number determine which?
Thanks, Ben
Hi Matt
Thanks, Ben
The intake bolts are roughly 9” apart on a B engine and 10” on an RB.
