Ok got some time today and still can't solve my issue.
I'm typing this on my phone so apologise for errors.
No load, car off 12.7v
Car on idle 12.5v
Rpm about 4000rpm 12.6v but no higher.
High load (headlights radio on) 12.3v (or maybe 11.3 I can't remember)
High load high rpm 12.37v (maybe 11.37)
I tested the resistance of the cables from alternator to bulkhead, to ammeter to bulknead to starter relay to battery and resistance was <0.5ohms. Even ammeter had low resistance.
I tried bypassing ammeter by bolting connections together, no good.
I tried running anothere cable in parallel from no he alternator straight to the battery, no change at all. Using this method I think I can rule out any wiring issue as there's a path of very little resistance but no increase in voltage.
I also tired running a cable straight from alternator to the connection to the ammeter (because the ignition needs voltage to start and branches off there), also bypassed ammeter and still had luck.
The alternator is brand new, 100amp dual field with 1 field grounded. I tried switching fields aswell.
Regulator is fairly new, however it appears to be regulating voltage as it's constant, is just not the voltage I'm expecting. It's a mechanical regulator btw.
The resistance from ground to alternator is 0.2ohms and I've replaced the main negative cable to the block and added a cable from block to body aswell.
I'm out of ideas. I haven't checked the field terminalservice circuit yet but am I right in saying it wouldn't start of coil or ballast resistor were faulty? I did check the coils resistance and that was 2.5ohms, I think that's fine?
Only thing I haven't replaced is the battery. But I don't think it's battery related because it never gets above 12.6v from the charging system.. anyway it's a callium battery that's about 3 years old. I have charged it a few times over the years with a mains battery charger.
Hope someone can decipher all this and has some advice!!!
Car on idle 12.5v
