Okay since installing the green bearing and having everything apart it seemed like a good idea to replace all the brakes.
New wheel cylinders (O'Reillys)
new shoes (auto zone)
new springs (auto zone)
new drums (summit racing)
new hyd hose and new steel line on axle housing
drivers side works fine
pass side climbs to 350 degrees in just 45 minutes of in town driving
other three drums measure 120 - 140 degrees
I have had the new drums turned
even had the axle trued. The flange face had a .008 wobble in it.
Still cant get this brake to work right.
any ideas out there?
I have re-replaced the shoes, wheel cyl, and even tried a heavy duty spring set (dorman h131)
I even turned the adjuster wheel backwards in an effort to keep the shoes from self adjusting and making contact but that did nt work. I'm beginning to feel that it is a hydraulic issue.
I need to take this car on a 8 hour trip up to St Ignace for the show on the 27th
