You given me quite a lot to think about thanks so much John...it's looking like I have Ford parts in my brakes...Hmmm
I wouldn't panic too much about the Ford parts. A lot of common service parts were/are shared among manufacturers.
The brass float for the fuel sending unit in a '67 Newport is the same as an '89 Crown Vic wagon.
Here's a pic of the '67 Chrysler FSM:
It looks to me like you have the adjuster spring correct, if '68 is the same.
If you don't have an FSM (Factory Service Manual) you really should add it to your reference library. They are readily available and worth every penny. I got two of them from eBay.
Chilton's and Haynes are decent, but there is no substitute for the FSM.
Another item that I found to be invaluable:
1968 Plymouth Fury Color Wiring Diagram - ClassicCarWiring
Not sure what year Big John's pic is from but it doesn't match the '67 pic.
Hope the input helps, and doesn't confuse.
John
My pic was a screen shot from my 69 manual.
Here's a link to some downloadable FSMs.
MyMopar - Mopar Forums & Information - Service Manuals
There's a 68 Plymouth there.
E-brake Still Hanging Up!
Even with new rear e-brake cables...passenger side still does not release properly...I've taken the rear passenger side shoes off again, deburred the e-brake arm and the horizontal center link, never-seized e-brake arm pivot point (it's nice and free), reassembled and still...when I release the e-brake...the rear passenger brake stays locked up. I have to fiddle with the e-brake cable to make it let go. I've swapped positions of the cables in the frame bracket (near adjustment stud). I've removed passenger e-brake cable from it's 2 restraints. Tried adjusting the brake shoes loose to snug...Tried adjusting e-brake cable loose to snug. Nothing makes a difference. It's almost like the spring on the passenger e-brake cable isn't doing it's job?...but it's brand new?
I've had brake shoe releasing problems in the past with other vehicles. Because of this, I'm aware of "wear grooves" in the stamped pads on the backing plates. When I replace brake shoes, I always touch up/clean off these resting pads with with a small grinder. Because this is a low mileage car, I didn't see hardly any wear grooves in these pads. Still, I touched them up/cleaned them off...so I can eliminate wear grooves as the culprit here. I'm at a loss why the passenger side e-brake won't release...
Bob
I will confirm that your brake set up matches what I have in my 68 Polara and in the 68 FSM
I didn't see this in the responses, but what happens when you put the e-brake on and release it with the drums off? Does it return like it is supposed to? Or does it still hang up?
I'll try to get a few photos today...Whoops I missed that one.
Bob, when you get a chance could you snap a couple more pictures? One with the parking brake on ( want to se pics that show the top return springs, and the brake cable under tension). Is the cable wedging on some thing when it is tight?
Next a picture of the brakes with it released before you mess with the cable ( same two pics as above). Maybe I am wrong , but shouldn't the main return springs be helping return the brakes more than the little spring on the cable?
Marty
Thanks for taking the time to take the pic's, but you are right, they aren't telling me much. It looks like your cable is completely free, and the top of the pads shouldn't be hanging up on the pin.
If your extra springs are doing the trick, I would say that John A. In post#23 on the weak cable springs called it. I would have thought the brake springs would have provided enough force to return the pads.
