cbarge
World Famous Barge in a Budget
Yes. Remove the intake and get a new intake manifold gasket. Block off the heat crossover passage.Timing at idle is 11* and at 3500 it is 36*
Also should I start looking at blocking off the heat riser?
You have a carb with electric choke so you dont need the crossover.
Use heat sheathing on the fuel line and use carb spacer.
Speaking from experience 66 383, engibe at operating temp 205F ,base of carb is at 109!!
No more hard starts or long cranks sine no more perculation.
