Grits
1965 Fury III 318, automatic
Carb numbers looks like: 38482A and below the numbers is B5
Under mild acceleration runs great. Under maybe 1/4 gas petal acceleration engine stumbles, back off on petal and easy on runs great. At 40 MPH and above runs good and accelerates good under mild petal. Easy petal to floor accelerates good. I removed and cleaned carb and set both mixture screws. Vacuum to spark advance good. Vacuum advance is hard to move with distributor cap off. Used screwdriver to push on advance and moved but was harder to move that I though it should. Any suggestions?
Phillip
Phillip
