Mr C
I think there is sediment clogging the sock on the pick up in the tank. As Commando said, the system should work...it does on all of my cars/ truck.
its the pickup in the tank
Where did you install the electric fuel pump, anyway?the electric pump starved for gas after about 20 seconds of running.
1966Newport maybe wins.
The next thing, last thing, only thing left, is the sending unit.
Everything else is new.
im trying to be positive about the whole experience, now when I get the 670hp motor im wired for an electric fuel pump...
Don't be shocked if it does the same thing again, you still haven't gotten rid of the sediment in the tank and its likely to do the same thing again. Some of the sediment is probably magnetic, maybe even most of it and if it is you can control it by getting some strong hardware store magnets and attaching them to the lowest part of the outside of the tank. This will keep the sediment from floating around and eventually being drawn to the suction at the sock.
I'm pretty sure you'll get better gas mileage with those magnets on there too... its like a paranormal phenonmanum, phenonunum, you know....supernatural magnetic gas milage booster magnets..
