swisherred
in that picture the kickdown lever has no return spring...so its really almost fully engaged as if at full throttle...it comes all the way forward to the carb...I just dont know the physical differences between the parts.I have done a few 2bbl to 4bbl conversions before, but have a large box of misc rods and linkage form parts vehicles over the years to draw from. I also will cut, bend and weld if I need to extend a rod or ???
My guess why that rod is upside down is that it is for the 2bbl cab and would have been mounted on the other side of the bracket and in the correct orientation, but that would but the mounting point for the kick down on the carb in the wrong spot, hence the flipped rod, at least it mounts up now. But you may not have enough adjustment to get things set properly, looks like it's threaded out almost all the way now.
does anyone have a picture of the proper setup so i can compare?
