Watch the personal slams!I wasn't taking about your personal life
We're just joking.Watch the personal slams!
Wow! I married her.
Curious, are you running a breaker point trigger for that MSD 6A? I've been meditating on something like this for our family ride, even though Gertrude runs reasonably well with the venerable Kettering setup the car was designed with....my exhaust temps are around 900 degs , very hot cam .
Hall Effect trigger requires less maintenance than breakers, for sure! I like my breakers, but sometimes speculate about using some primitive CD w them. MSD isn't primitive of course. Having got this old motor doing so nicely with the turn of the 19th to 20th century stuff, that I don't really care to change it. If I really want extra power or must comply with harder Emissions regs, I might do it then..... Good to see that the MSD boxes are so versatile.I like using the factory Mopar electronic distributors with the analog 6A/6AL MSD boxes. Have set up several cars that way and they always work well.
Yah, I can believe that. Not likely I'll do it. I've probably reached the acme of performance on stock, single point performance with this 383. It does well enough with the Taylor coil, solid core copper wires and platinum plugs. I got back 270 ppm of hydrocarbons in the exhaust, where the legal ceiling is 450. I see the crankcase oil is a bit dirty, so I reckon changing it soon will do good for this and CO. Dwell still sits right on 30 degrees, so those points are doing as I set them to. I don't think a CD would be good for this old school setup. Now a Mallory dual point dizzy might do well here....I tried an msd box and points once, it burned the points out pretty quickly
I run the Streetfire box that is made by MSD. It is made in the USA. I use it with a Mallory dual point distributor, and it works great.
You have one of the old "good" ones.I haven't bought an msd box in at least 15 yrs, maybe 20. Haven't had to replace any, so the vintage I have are good but I can't speak to more recent ones
3 of themYou have one of the old "good" ones.
Perfect.3 of them![]()
