69 300 vert
Experts: thoughts?
40k volts will produce a spark the same length regardless of how the coil is triggered. Dave
40k volts will produce a spark the same length regardless of how the coil is triggered. With all things being equal the vehicle would run about the same. The important caveat is that there are no wear parts in the HEI or other electronic ignition, no points to go out of adjustment or corrode and no distributor condenser to fail. Points are a time tested and proven method of ignition that can usually be repaired on the road with a simple adjustment or filing of the contact set. Electronic circuits when they fail usually stay dead and a tow is usually necessary unless the user carries spare brain boxes and modules. So which is better? My choice for most older car applications that are not driven a lot is to stay with points. There are increasing problems with finding quality replacement points and condensers, so some ebay surfing is necessary to find US made units which are far better than China Crap. There is also a lot of problems with electronic ignition components that are made overseas to very low standards of quality control and a lot of new Electronic units fail pretty quickly. If choosing to go electronic, be sure to buy a unit with US sourced electronics and it should perform well.
Rich Rehrenberg supplies units that have all US sourced electronics and they are not that much more expensive.
I the real world with both applications using the best quality parts available I find the Chrysler version of HEI to be rock solid reliable. Always starts My 300 vert For the past 8 years and 8000 miles. A points and condenser can't do that.
I noticed he wasn't using a ballast resistor when running the points, not that you would for drag racing I guess. How big would the arc be with the coil running 6 or 7 volts with the ballast as on a street car?
Thanks Dave for this. I have asked so many people this question and never got a logical answer. Question being , On a points ignition with ballast resistor which coil should you run, a 12 volt coil or a 6 volt coil? 95% said "It's a 12 volt car and needs a 12 volt coil." Then I say that I have read that putting 6 volts to a 12 volt coil will not be 1/2 the output voltage, it will be less than half. They were not convinced and not one person has ever said use a 6 volt coil. After researching this I stuck in a 6 volt coil in my 440 and have had no problems and my plugs are always a good color and never fouled and are clean. I have run this coil for 3 years now with no problems. I guess you could use a stock 12 volt coil and remove the ballast and of course wear out your points in short order ,maybe the condensor too but does a 12 volt rated coil on 12 volts put out more spark energy than a 6 volt coil on 6 volts and if so by how much? I do know a 12 volt coil on 6 volts is poor.
Now I just wonder how many guys with points stuck in a 12 volt coil and had problems and it was cured by going to electronic ignitions? I think many. Then say "Points SUCK!!"
The 12v coil with the ballast resistor removed actually puts less load on the points than a 6volt unit. Trick is you have to use 12v rated condenser.
Are they available? Never seen them.
