Help for 78 Chrysler New Yorker
Moseman
Chancellor, SD
I know it probably has been posted here before. What do you do when you need to repair the heater/ac control module? I have a 78 New Yorker that need the heater controls.
Does anyone know how to repair or someone that does? I am sure all of the good used ones are gone!
Thanks ahead of time!
Are you talking about ATC II system?
I believe so, It has the temperature control that has degrees of temp, and the various functions as pushbuttons. My mechanic has the a/c working and converted to R134, but has stated the control is not working and the heater valve does not work. It is stuck in the open position.
I can send a picture if need be.
Thanks, Clark
Is this what you're looking for?
http://www.ebay.com/itm/Mopar-1974-1978-Dodge-Plymouth-Chrysler-A-C-heater-switch-3846083-NOS-/261540924883?hash=item3ce50dcdd3&vxp=mtr
There is a few guys here that can help with ATC II systems. Both of my 78's are manual A/C (Thank God!) and are relatively easy to work on and maintain.
Thanks, I hope someone has some ideas. I believe the ebay listing of the part in Lebanon will not fit.
If you post a picture of what you need I could see if I can find you a part number. I have the 78 parts manual.
My NYB was converted from AT II too conventional a long time ago. So it is possible to do. Don't give up hope.
