fury fan
And that's exactly what I was wondering about.If I would have done this again, I would have moved the transmission forward one inch or so and would have installed a longer driveshaft. That way you get enough clearance at firewall and retain the truck setup completely (I like it better because alternator is not sticking out to the side).
The other conversion on the Drydock is using a FEAD with the alternator at the side, and he had to notch his control arm bracket for clearance. I would want to avoid that, and also get the engine away from the firewall pinchweld, so interesting that 1" forward would allow the truck engine (and intake) to fit better as-is. And truck engines seem to be about $1000 cheaper from my research. Sounds like the $2-300 on driveshaft is a good investment, the other incidentals at the transmission area shouldn't be too bad.
Moving it forward would make the motormount brackets less cantilevered also. And I presume this engine is lighter than a BB, so moving forward doesn't degrade handling too much, still should be better than a BB in the stock location.
What about the oilpan I wonder??? Would that Milodon still fit? I would not want to modify the oilpan, my skill isn't that high. (small boats should stay near the shore, as the saying goes)
BTW - what is the elec box on the pass-side firewall? The ECU?
