welp finally got headlights working properly...turns out both hidden headlight relays l had were toast....
Picked up a 5 pin bosh style relay and hooked it up as per diagram below and found out l hada swap the two leads to motor over to get it to open properly as doors would open on OFF position and close on on position...anyway was just a matter of switching 2 wires thank god
anyway blue and yellow wire go to 87A
black with red tracer to 87
k....have low and high beams..doors close and open properly...just used one relay and added the 30 amp breaker from original setup....any reason l shouldn't just leave it and call it a daY if it works??? these diagrams with 2 relays are screwing with my brain...relay for high and a relay for low beam????
personaly am of the mind if it works with one relay just fine don't screw with it...anyway am happy hidden headlights are finally workin..
