Hey all, I've been running a Tuff Stuff 130amp alternator, but now that I have added Dual Fans I found its Achilles heal. Low RPM/Idle Charging (or lack thereof). Looking to switch to a GM 10 or 12SI unit.
The question: Who has the best Idle output that you've seen?
NOTE: I have already done all the re-wiring, 1ga feed direct to battery, 8ga Alt Ground. Relay 12v signal wire direct from Battery to regulator, bypass Amp Meter etc etc etc. I really don't need to be versed in what old Mopar did and why, just want honest opinions about GM 10/12SI manufacturers.
AC Car, Convertible Car
Aftermarket Stereo and Amp
Contour Dual fans (this is the one that pushed things over the edge)
Sniper Injection
Hyperspark Box
FI fuel pump
Group 27 AGM Battery (New)
In general, rough math is looking like I'd need somewhere around 95amps at 800 RPM Idle. Mopar Tuff Stuff Alternator is spinning at ~2200 rpm. When sitting in traffic at idle with everything going, it's dropping below 12v until about 1500 engine RPM's then it comes up. Regulator is good, swapped in 3 new ones and all had identical behavior so I know the Alternator isn't up to task at Low RPM.
EDIT: Looking at this Alternator. Seems to have the exact same mounting as the 10/12SI. 145amps output at Idle.
Powermaster 857296-1 Powermaster HPR Small Frame Series Alternators | Summit Racing
