- Joined
- Nov 14, 2010
- Messages
- 28,339
- Reaction score
- 27,912
Yes for pushrod on the 383.
I've been trying to score a shroud for sometime now. I know it's conducive to have one in place....finding ones that are not already damaged or bent is difficult. I usually run at 195 although I did see it inch at bit towards 200 degrees once at the end of last summer. If I can find the correct shroud, in decent shape, I would be extremely happy.A shroud would make a big difference. You will go from basically moving a bunch of hot air around the engine compartment and bringing a relatively small amount of outside air in through the radiator to drawing in all fresh outside air through the rad. You may not be overheating but you are likely running hotter then you need to be. It only takes 1 degrees to much to boil your fuel...
thank you!!!didnt say that. But i hear guys screaming vapor lock frequently and its usually not the reason. The car ran fine for forty years, now its hot?
Right. The cookie cutter approach. Ok.thank you!!!
A million CHiP 440's idling all day in the median strip in 95 degree weather had no problem...
It's just a number of different ideas bouncing around. I may do it or may not...I have not decided yet. I have all fuel/pressure rated hose from the pump to an Edelbrock elbow that connects to the AVS carb, and a spacer plate under said carb which all together made a REALLY big difference last summer, but as I said its starting to get hot here and the problem seems to be reappearing.......somewhat.It makes no sense, moving the line may make it work but wont resolve the problem
A part of the reason why I'm headed there next month.2785435 is the 70 part number for C body cars with air
http://www.ebay.com/itm/plastic-fac...Parts_Accessories&hash=item3a818c914c&vxp=mtr
http://www.ebay.com/itm/CHARGER-ROA...Parts_Accessories&hash=item460b2093c7&vxp=mtr
3443522 is the 1971 part number for c body cars with air
I broke the one in my 71 right before Carlisle and found one up there for forty bucks. Maybe worth the wait.
