How to clean a gas tank
spstan
Rochester
Watching Simon Fordman working on a Torino on You Tube. The guy is brilliant (no words spoken, no emotional outbursts when things go wrong; just a steady, methodical step by step process). So he takes the gas tank out and puts nuts and bolts and chains in the tank. Then he welds a bar to the back wheel and straps the gas tank to the bar. Then he starts the car, puts it in drive and lets the rear wheel spin the gas tank. He then empties the tank of all the bolts and the chain and the rust and puts a couple of gallons of muriatic acid in the tank. Tank comes out almost perfectly clean.
I want to clean the tank on my New Yorker but I don't know if I could do this process. What's the best way; take it to a mechanic or a radiator shop? How much should I expect to pay? Thanks Paul
Depending on how dirty/rusty your tank is, there is another option. Mix up 5 gallons of HOT water with a liberal amount 9f dawn dish soap. Get a carton/tube/box of BB's and put them in the tank with the soap. Shake, rock agitate the tank for as long as you feel is necessary. Dump it out over a piece of screen or a strainer to catch the BB's. Rinse it out good. Not clean? Do it as many times as necessary. Satisfied with how it looks. Let it set for a couple of days to dry out and reinstall it.
Take it to a radiator shop. They can hot tank it. They drill a small hole in a corner for drainage, then weld it up when finished. Works great!
OR . . . you can send it to Gastank Renu and let them work their magic on it. Separating the halves, cleaning, and welding it all back together again, with the end result being a "new" tank assy. Shipping can get expensive as the basic service used to be over $500.00 USD about 20 years ago.
Otherwise, find a good radiator shop to do their deal on it.
IMHO, it would be worth pricing a new tank. Cost to have it professionally cleaned might exceed new.
The real question is how dirty is your tank? Does it really need to be cleaned?
