How to test temp sender and gauge with only a multimeter?
edbods
Australia
I finally got my car fired up and man it's a great feeling getting it running again. But unfortunately, I noticed that my temp gauge barely moves from stone cold even though the engine is scalding hot. The fuel gauge works fine, which implies something wrong along the sender circuit. Is there any way to test the gauge and sender with just a multimeter only? I took the gauge out of the dash and got 20 ohms resistance between the two studs with the needle at its lowest point, dunno if that's what's meant to show up though. Unfortunately, at the moment I can't get easy access to the bits and pieces needed to make my own C-3826 tester, or at least, I don't know what bits to cobble together to make a homemade version. Also, the sender appears to take a female spade terminal/connector, instead of the screw down ones that seem to be on later models, not sure if that changes anything.
What year car is this? You can test the gauge by taking the lead loose from the block sensor and grounding it out to the block. This should peg the gauge to the hot side with the key on, don't leave the key for very long as this could fry the gauge. Since you have some resistance, the gauge is probably ok. If the gauge pegs, most likely the sensor in the block is bad. If the gauge does not move, trace the wiring back to it and check the circuit board on the back of the instrument cluster. Sometimes the circuit pathways get fractured after long use. Since you have a working gas gauge, the cluster regulator is working. Check the gauge for cob webs as those can block the movement of the gauge needle on a vehicle that has long been inactive.
From the sensor, it should read about 80 ohms at 120F, 32 ohms at 170F and 13.5 ohms t 230F. The gauge goes higher as the resistance drops, with little or no resistance, the gauge is pegged. Check the sensor with the lead removed on a hot engine, if you have high resistance once the car is warmed up, the sensor is dead.
Oops. It's a 67 Phoenix/67 Fury with the 383 engine. But the temp sender looks like a 66 and earlier model, takes a female spade connector. Hooks up to a 66 Polara/Monaco gauge.
@Big_John thanks for that. Gonna see if there's a local version since shipping will kill me for such a cheap tester. Don't have to worry about using OG mopar stuff with me, I try to where I can but at the end of the day I'm not a concours purist.
Edit: and whaddya know, people sell them here too! Seems like the shipping is already part of the price though, 75 bucks RIP.
Did something similar with my oil pressure gauge. Grounded the wire to the block with key off, turned key on. Pointer swung all the way across. Turn off again. Repeat several times, then reconnect. It read much better after that - I guess the "exercise" must have knocked something loose.
I find a bottle of this stuff is always good to have around, too. Works on stereos, power tools, cars, just about anything with a circuit: https://www.guitarcenter.com/CAIG/DeoxIT-D-Series-Contact-Cleaner-Rejuvenator-with-Adjustable-Low-Med-High-Straw-1500000376175.gc
I had a similar issue on my New Yorker where the gauge moved a bit but didn't seem realistic. I slid the cable off of the sensor and cleaned up the contact points on the connector on the cable and the sensor, reinstalled and then it started registering right in the middle of the gauge when it was at normal operating temperature.
Thanks guys, and thanks again @Davea Lux I'll try those tests. Didn't even think to test with the multimeter like that. Electrical work isn't any stranger to me, but too many times I forget the basics.
If the Ford tester is a little out of budget, you really only need a 100 OHM pot, a case and a couple of wires. Use your ohm meter to mark the values. I think I found the pots on Amazon for a couple $$.
I had an old non metallic fixture box for the case.
Low or empty 74 ohms
Med or 1/2 23 ohms
Hi or full 10 ohms.
Yessssssss, it's just the temp sender! Pulled the spade connector, sat it against the distributor body, turned the ignition to on, and the gauge shot right up. Thanks yet again everyone!
