commando1
It's a well known serious problem to everyone that's been around these cars for a while.
(Sent using Forum Runner)
Yeah, guess I lucked out in that aspect. I think I'm going double wrap that wire so that this doesn't happen again.
If those weren't the source of all your problems I'd be suprised! I hope you find no more suprises.
Routing cables and hoses is so important. I replaced all the fuel hoses on mine and started it up to check for leaks. The fuel hose from the fuel filter was a tad too long and shifted a bit and in a matter of 30 seconds the alt belts almost rubbed all the way through the fuel hose. I was lucky and caught it. Disaster averted.
It could have just been old and corroded, which increased the resistance and power dissipation and .... I think you can get them in bubble packs in auto parts stores. Another option is to put an inline fuse holder and a large blade fuse. I would guess a 50 A fuse would work unless you have a thumper audio system.
But before that, measure the resistance to ground with the key switch on (not in crank). If <1 ohm with headlights and other accessories off, you probably have a short to gnd. Find it first so you don't blow $2 fuses. Can get a multimeter cheap or free at Harbor Freight.
If you learned just a little bit of electricity, you could have saved the time and cost of a tow. Running a jumper wire direct from BATT+ to the upstream side of the ballast resistor (other wires off) would have powered your ignition system and it is simple to jumper the starter relay.
Agree 100%. You did the right thing. Jumper wires on the side of the road is begging to catch her on fire. Get her home, take a deep breath, get rid of that crazy 1,000 volts to the gauge deal & move on.well, lesson learned I guess - although from my standpoint, I'm not so sure how prudent it would have been to try and run jumper wires here and there, on a 40+ yr old car that still has OE wiring (and maybe other fault areas-at the time there was no way to know), in an attempt to defeat a fault condition that was meant to occur for a very specific and serious reason. No, I'm glad I got her home safe and sound without having to worry about "what's next" because of a quick side of the road temporary fix. And the tow wasn't that bad, my insurance covered it......
N-a-t-i-o-n-w-i-d-e was on my side.
Nationwide is not your friend btw. I deal with insurance companies for a living & I live in Columbus, nationwide's home town/headquarters. They are NOT on your side.
Road side assistance is pretty easy to get right. I hope that you don't have to file a serious claim.They sure as heck were last Friday at around 4:35 pm
