twostick
I'm probably done putting "old iron" engines in cars. If I were to do another car it would be a Supercharged Gen 3 in a Forward Look DeSoto. I would really like to do it in the next 5 -10 years if I was to do it. It would require a lot of research and possible fabrication to mod a 44 spline axle or maybe a Dana 60 to work in a Forward Look. I haven't seen anyone do that yet with a 44 spline axle!
Call Dr Diff to supply the correct width Dana 60 with the spring perches at the correct location and it will just bolt in.
It's overkill in my opinion unless you're planning on running 9's with your Desoto which would be no end of cool but a Cbody 8.75 housing and diff is more than up to the task if you don't put slicks and a trans brake in front of it.
Lots of 500" strokers running around making 600+ ft/lbs.
Kevin
