monaco75
If you haven't bought the command centre yet you need to realize it costs more than the other kit they offer. Plus you need to add fuel lines to hook all that up the command centre. Technically you'll be saving money by taking out what you put in. Which probably didn't cost very much as is. Also that 40005 kit is a bargain as the pump and large filter alone is worth over 200 bucks.
Yes I am running a locked out MSD distributor and a 6AL box in order for the Fitech to control the timing. Will see how that works.
Also I recommend finishing your exhaust with o2 sensor and doing the break in with the kit. I learnt a long time ago that trying to break a motor in with open headers is a bad idea. It's so loud you can't hear if somethings off or wrong. Whether it be misadjusted rockers or a rod knock or detonation or anything potentially disastrous.
Sounds like you have a new motor so I'll highly recommend a proper break in oil like Joe Gibbs BR or Brad Penn or Royal Purple.
Yes, but the command center comes with the lines needed. Which doesn't look like much. Just a line from the pump to it, then out of it to the throttle body.
"New" to me engine has a few miles on it. Has a new cam to be broke in. Will deff run some good break in oil when the time comes.
I know of two issues, well 3 so far. The floar on the command center used to get stuck on earlier runs, they have fixed that by now. The supplied high pressure line used to burst, they have also fixed that and supply a russle brand line. Then with the tune, if there is an hesitation, you have to adjust the throttle stop to get the iac between 6 and 10. Thats the only things i could find.
Thank you! Thats what I wanted. Some actual problems, which seem to have been corrected. The command center could take place of the charcoal canister under the hood perfectly imo (if equipped)
