patrick66
It's not in a C-body, but in my '68 D100 pickup with automatic. I just finished the lowering job on it last month (Sid's dropped 3" stock axle, along with a 5" dropped rear with modified rear shackle mounts). Engine is a bone-friggin'-stock 2-bbl with original everything - exhaust, carb, points distributor. I fired it up and had a slow time getting the lifters pumped up. There was 60 lbs of oil pressure at this time. I added Seafoam and removed the valve covers. I changed the filter to a WIX 51515, and added a quart of 10W30 oil. I started the truck and the lifters were pumping away, with plenty of oil now reaching the rockers. The rattles went away, and it sounded pretty good. Reattached the valve covers and let the truck sit for an hour. Started it back up, and it sounded like ****!!! It has some major noises coming from the front of the cam gallery! I figured I'd bent a pushrod or three, so I left it alone for a few days.
On Sunday, I removed the rocker assemblies and the pushrods - I have 16 perfectly straight pushrods! So, where else might the noises be coming from??? A couple of dead lifters is all I can think of right now. It holds 65# of pressure cold, then about 40# as the engine warms up. It now started popping back occasionally through the exhaust, which it was not doing before. The truck had sat for a little over a year as I was doing the suspension mods. It ran beautifully beforehand!
So, before I remove the intake to check the cam and lifters, anyone have any ideas what's up?
