Boomer
Been tinkering a bit more on the '66 300 today, specifically the console shift area. Got the two dome/courtesy lights working a week or so back, opened the vacuum gauge to find a burned out #57 bulb but had no replacements.
Got replacements this past week and installed one today. No light. Checked the shift indicator which was also burned out, thinking they might be in series. It was toast, installed a new one, no luck.
The service manual diagram shows a separate fuse for the lighting. Looked up under the dash and found a single fuse holder, but it ended up going to the 4-way flasher. Difficult to see much more in the limited space (A/C hoses, etc). I have not removed the top of the console and checked in there, only popped the top enough to change to shift bulb.
Hoping someone can point me into the right area to dig so I don't needlessly start removing things looking for something that isn't there.
I should also add that the dash lights are (currently) working with the headlight switch. It's just the center console instruments that are out.
Thank you.
Thank you.
