Giovanni1776
Ok I got it
My car were supposed to be built on 31 of Marc
But been built on march 23
When starting these old 4 bbl carbs after a few days, first you give it a full to the floor and back shot of gas just incase there is enough to fire. If not do another then turn engine over counting to 4, give another shot and turn engine over, if no fire just repeat. This will keep the starter from over heating and your battery from going dead. (maybe) Don't keep pumping while turning over like a rabbit have sex. The rapid pumping will wear your shafts and throttle pump. As for the mist from carb/ air cleaner it sounds like you may have full percolation going on, fuel boiling and some run on. What is your engine timing, condition of rad? Do you know how hot your engine is getting. Did Nick not do a full tune on the engine for you?
Unfortunately I don’t have any of thoseDo you have a timing light? vacuum gauge?
Couple thoughts:
Does the choke work properly? Reason I ask is, I had a 65 New Yorker with 413 and my not knowing the choke wasn’t working on cold starts! She was a ***** to get started.. once warmed up! Ran like a champ.
Second, these cars have a history of “Heat Soke” during hot weather, being so hot the fuel boils out/ off from the carb making her difficult to start.. assuming you have the OE carburetor setup on the engine..
Just my 2 cents.
That might just be fuel vapor coming up through the carburetor through the air filter , and then out of the cleaner, just an uneducated guess..Very informative thank you very much
But what could make my air filter to smoke ?
I read something about the breather ..
It seems to be exactly what happenedYou heard the odd noise from engine when it was shut off, but the engine didn't quiet shut of right away? It kinda coughed? If so that is called run on, your engine tune is out. If it is running on, that is usually from timing retarded, idle screw is set to deep/open to compensate for the restarted timing, the restarted timing causes a hot running engine and the misery continues.
I've just fixed the "run on" issue with my car, the idle mixture was too rich. I had tuned the idle mixture in march, when it was a lot colder, now with the warmer weather (and less dense air), the mixture became too rich. I leaned it out a bit and I have no more coughing, sputtering, or smoke upon shutdown
Absolutely!Wow
Can I ask you how you did it ?
