- Joined
- Nov 14, 2010
- Messages
- 28,565
- Reaction score
- 28,449
So I finally put the booster back in yesterday just to find that the Auto Pilot is probably going to have to go.
If it were just The lines I’d try to make it work but it’s more the rigid linkage to the auto pilot itself.Damn that is too bad. Are just the lines obstructed by the autopilot? Are there 90 degree adapters which can shoot the lines straight down first to give you some room?
I’ve gone 10 years with a non working Auto Pilot in the silver car which I will eventually get working and probably rarely use. I think I can just let it go on this one.Would it be possible to retro fit a '67 style Auto Pilot in there?
I'm only worked on the later units. The earlier ones I suspect to be even more a PITA.Did you have one of these mid-sixties "Auto Pilot " ones Stan? They are completely different than the ones of the '70's. But still a pain in the ***.
I've got some of the newer ones that don't work either. They are a pain!
That's a bummer, just because I really like to see the original hardware under a hood... especially stuff folks don't see much of these days.So I finally put the booster back in yesterday just to find that the Auto Pilot is probably going to have to go.
You know I’ve thought about it Jeff because I feel the same as you but I’ve got a lot of battles to choose from these days and getting this car to driver status is a major one, not wondering how much it’s going to cost to get the Auto Pilot working.That's a bummer, just because I really like to see the original hardware under a hood... especially stuff folks don't see much of these days.
Just a thought, if you wanted to keep it, how hard would it be to make a new rod that would fit/work better? Might not be too difficult to just start over with a steel rod and adjust the length/bends.
In short, yes.So you're saying that having good brakes, out weighs Auto-Pilot?![]()
