70bigblockdodge
In the manual they call it a track bar.
The manual calls it a rear engine mount the rest of the world calls it a transmission mount.
I'm glad you got her a bit more sorted for the trip. Congrats again... guess I was right the first time "Happy Imperial Cruise". I can't think of a better honeymoon, surprising she is all in too... Very lucky man indeed!So yesterday Bob(CLover) came over to help get the car ready for the road trip. Most importantly he installed the new(and hopefully last) turn signal switch, this makes the third since I've owned it but the first one using an NOS switch. Next was the e-brake release/reverse light switch hasn't worked since I've owned it in spite of installing an NOS switch when I bought it. It turns out there's a plastic piece within the column that engages the switch and it was broken. Once the broken piece was repaired the switch operates the e-brake release and the reverse lights as it should. He also figured out why I have had almost no control over the heat. It was a combination of a couple of things. The Imperial non ac heater box is similar to a B-body in that there's no valve that would shut the heat off to the cabin, just a cable controlled door that keeps the heat in the core. This door was sticky which in turn messed up the cable and it's mounts and the fact that the heater control vacuum switch itself was cracked up pretty badly didn't help either. I've had rags stuffed in all the floor vents to block the heat since before Taking it to Carlisle a couple of years ago and now it's in working order although I still need to replace the broken parts as the band aid type repairs may not last forever. While under the dash he found the low fuel relay isn't hooked up but ran out of time to figure out why. I will probably look into that while on vacation.
Lastly was a quick look at the auto pilot to determine that the unit itself is bad which he figured was the case so he gave me a known working one that he had in his stash. That will be an easy swap but also ran out of time to do it before we leave. I couldn't thank him enough for all his effort and expertise, the man is like a machine when it comes to these cars!
The trip will probably end up being about 2K miles of top shelf style Imperial cruising!
Godspeed on your journey.![]()
