A few good things today related to getting the ATC back up and running:
I swapped out the actuator to test it with the salvaged spare and it worked perfectly. Did the same with the ambient sensor and it also worked.
Two other spares to add to my collection.
Ditto both vacuum motors. I also have a brand new spare heater core and a possible spare evaporator if it checks out as good too. I can add in the spare vacuum lines and their rubber ends to the list. Last thing to check will be the blower resistors. About the only thing I plan to get rid of will be the airbox itself except I’ll need to to keep all the spares in it.
Sent broken amplifier out to get it fixed. You can’t have too many spare amplifiers. They are definitely the weak link in the system and from what I see they just simply burn out. The rest is fairly straight forward and fairly easy to diagnose.
Speaking of which.... I’m into the diagnostic section of the other thread. I need to finish taking all the pictures and just get it done.
Finally, in case you haven’t noticed, I edit a lot after posting.....so some of the longer posts may be worth checking out again.
Javier
Javier
