Do you guys even need a heater core in Florida?
It can dip into the 40's at night in February.Do you guys even need a heater core in Florida?
You've been reading Javier's work... normal good advice is unnecessary... you should be telling him to use a magnetic drain plug to catch any metal when he breaks in the new engine.I'm sure you will but I would replace the valve guides and seals and get a valve job on the heads since you'll have them off.
Probably a new Edelbrock but not much else.or if he will upgrade anything while in there
Which is why I hadn’t done it yet. Thinking about just pulling the damn engine out and rebuilding it with perhaps a little more lift cam. For now it runs ok.You've been reading Javier's work... normal good advice is unnecessary... you should be telling him to use a magnetic drain plug to catch any metal when he breaks in the new engine.
I'm guessing it will go like this... heads removed... cylinder bore wear is confirmed... several $k later a perfectly detailed new engine compartment is revealed. The wildcard in all of this will be if it becomes a pure stock build, or if he will upgrade anything while in there.
C'mon now, you've already made the call to CME, haven't you? Drop Bob's name and probably save a few hundred!Which is why I hadn’t done it yet. Thinking about just pulling the damn engine out and rebuilding it with perhaps a little more lift cam. For now it runs ok.
You are assuring he will Never give up on that TQ...Probably a new Edelbrock but not much else.
He'll come around eventually ..
You are the first person that is more stubborn than my wife.
Or my cat for that matter.
Quite honestly I keep you about it to make you more committed.NEVER!
I'm sure glad you've been working the Jedi mind games on Javier instead of m...HEY... DANG... so that's how I became the Formal warehouse...Quite honestly I keep you about it to make you more committed.
Somebody has to give their life in getting it done.
Your efforts will not have been in vain, Jav.
And a damn fine Formal Warehouse you are! Thanks,I'm sure glad you've been working the Jedi mind games on Javier instead of m...HEY... DANG... so that's how I became the Formal warehouse...
Heater full blast today. Brrrrrr....It’s a four door hardtop with all the windows down and sunroof open kind of day....zooming around in my own personal parade float
Life is good!
At least it will be back to normal winter 70's-80's soon... I was starting to think electric socks would be a good idea.
Wanna see my camel toe???
