commando1
I disagree ...Change out leaf springs to something akin to GM’s coil spring set up but with bags.
You can replace the shocks with bags and keep your leaf springs.
Aren't those called air shocks?I disagree ...
Air shocks, Air bags, same function.Aren't those called air shocks?
Stan is correct. You don't have to put the coils on. I have air bags on my snapon truck and my motor home.I disagree ...
So question on this auto leveling system:
A lot of people on the online forums (well A and B body forums) frown upon load lever-ers and air shocks because these devices add additional load to the shock mount crossmember. Some say to the point that the crossmember could/would fail since that cross member wasnt designed to take that load, the spring mount points were. Did Chrysler redesign that cross member for the Formal Years? or is this the crossmember the same/similar to the fuseluge years? Are you going to add any stiffeners/bracing to the crossmember for this modification?
Great questions!
Unfortunately, I have only empirical answers at the moment.
I was not planning on reinforcing or stiffening the cross member supports/mounting points for the shocks. I’m only looking to level out about 300 to 500 lbs of girls and gas such that each would only see about 250 lbs of vertical load. But I may, if I see I need to.
Don’t know about crossmember redesign for formals but since I was planning a similar system to the stock available option, I figured it was designed to take the load.
Right now.....
I’m just past the wild hair stage of development on this and just beginning the procurement process for needed parts and supplies.
Then will come the mock-up/modification and execution stage...
To be followed by testing.
Done this a few times with success.
Stay tuned.
Didn't you replace the head gaskets in the last year?
Nice. Go ahead. Plug up your heater core... Your NEW heater core.Put some block sealer in and
Nice. Go ahead. Plug up your heater core... Your NEW heater core.![]()
Always with the happy thoughts Stan....
and I saved the new one and went with one of the old ones after pressure testing it, of course.
Hmmmm.... Now I know where a new one is in Florida.and I saved the new one and...
Yours if you need it.Hmmmm.... Now I know where a new one is in Florida.
Thank you for offering.![]()
I pray to gawd that day never comes.Yours if you need it.
