68PK21 440.6bbl
Out of curiosity, what did you hear that didn't sound right? I know there is a problem with the starter, which is that squealing noise at startup, a new mini starter is on the way.Yes of course there are big time benefits especially for a racer like you. I was just thinking that this kid might get a bigger bang for his buck for his stock engine with dual exhausts and a rear ratio change. Actually hearing the clip that engine needs some attention.
Don't tighten the f_@? Out of the flanges and use hi temp red RTV.You can't lose with headers
Thank you for all the info, I linked the headers I am planning on using on page one, so hopefully they fit, I have not heard of RTV until now so Ill look into grabbing that at Advance.Don't tighten the f_@? Out of the flanges and use hi temp red RTV.
Pick a set you think will fit. Everything from 1957-1976 had basic layout, dimensions changed, starter, bell housing trans pan all similar.
thats wrongDoesn’t require Cats before 1985.. ask me how I know! Lol.. Yonkers NY.
I took the cat off my 75 and 77 NYB and the car ran a bit better. No cat air pump on them either..
Why’s that?thats wrong
Hmm ok then. I believe you..you cant remove the cats by federal law
is that a 400 though? (too blurry to see if there's a top ID pad). 400 would have a little extra room.
