So, after doing some work on my '58 Imperial, I'm getting a weird stumble at times when driving it. It's kind of hard to describe it. The car idles great, and also accelerates great from or stop or while kicking down the transmission in passing gear. However, occasionally it stumbles, mostly while flat cruising at speed. The stumble is seems like the engine looses power for just a split second, then immediately recovers. You can even feel it, like one of the cylinders missed. The other thing is, it doesn't always happen. One cruise, everything is fine. On a another, I might get 2-3 of these stumbles. I'm hoping some of you gurus out there might have some experience with this and what it might be. Unfortunately, I have a feeling it might be a myriad of things.
Things that were replaced: Spark plugs, spark plug wires, distributor cap and rotor.
It still is running on the points distributor, and that might be the problem, but I'm not sure. However, the points were recently cleaned up and adjusted. I want to go with an electronic ignition before the year is out. I also still use a generator.
