I ran Motorcraft Diesel Engine Conventional Engine Oil 10W-30, for a couple years, being able to score a gallon from Walmart for ~$18, then Lucas hotrod/classic, then just added Lucas cam break-in zinc to 5 qts of Havoline. If I build an engine from the block up, with all seals for synthetic, I'll look into Royal Purple HPS, which lists 1200 ppm for ZDDP. The Motorcraft stuff has about the same.
I don't know if Rotella conventional STILL has a high zinc content or NOT. Does anyone know a RECENT authoritative reference to what they put in Rotella now?
