Jes give me my 13 over 2 way splitter dragin' ah 53'r and I'll parallel park it for yeah or don't talk tah me!!!!!!!!!!!!!!!!!!!!!!5 spd box with a 3 spd box bolted to it in series.
5 x 3. 15.
Easy Peasy
5 x 3. 15.
Easy Peasy
got lost around the 10th movement
5 x 3. 15.
Easy Peasy
Who the hell uses a cluch?(except in a Maxi-Torque five speed which sucked).
Never seen anyone who doesn't grind the gears on those transmissions.Anyway i heard some "grinding" in the 5x3 vid ..prompted the question again.
What in the world? My head will explode if you guys say he did that "clutchless".
seriously .. can anyone explain that ... from a technical logic standpoint .. as if I was a four year old? I can look it up but still would need a translator
hands off the wheel to shift? downshifting? emergency manuevers? one of the most complex patterns ever? what a SOB to drive as it seems?
Anyway, Mack B series, 1953-1966 models, Wikipedia says they had 5x3 ("triplex") and 5x4 ("quadraplex" - WTF!!) trannies too.
Generic photo below since I never heard of the truck at all. "Now dat's a real truck right dair."
I know and I never said anything about there being synchros. I was saying by letting up on the throttle while applying a light pressure on the handle, you could literally slide it out of gear. Then in that sweet spot of Neutral, you raise the rpms and apply a slight pressure to go into the next gear up. As the rpms go up, the gears literally slide in place when they match. You read the feel through your hand.There is no synchronizers in a big truck transmission. They would not last anywhere near the miles you can get out of a box (think 1million plus). All the gears are straight cut and the speed dogs and gears are all square cut, not pointed as in a A833 for example. Even if you use the clutch to shift you have to double clutch or engage it as you pass through neutral to slow the speed of the input shaft and the clusters matching the speed and being able to select the next gear. This is all happening with only 3-500 rpm swings, you kind of get the "feel for it". So since you have to engage the clutch as you pass through neutral it is just easier to pull it out of gear as you let out of the fuel and then wait till RPMs drop and stick it into the next gear.
Downshifting is opposite, you have to raise RPM in neutral to match next lower gear, again you get a feel for it.
The 15 speed in my truck basically works the same way as the triplex except I just have small air switches that shift the ranges not a whole extra lever. The deepest reduction is not used all the time, reverse, manuvering heavy load on a hill start etc..
Hope that helps a little.
Yes you are the synchronizer.I know and I never said anything about there being synchros. I was saying by letting up on the throttle while applying a light pressure on the handle, you could literally slide it out of gear. Then in that sweet spot of Neutral, you raise the rpms and apply a slight pressure to go into the next gear up. As the rpms go up, the gears literally slide in place when they match. You read the feel through your hand.
One what?I am one with my truck...
