Piston pin offset question.
Ok, I never read all the posts but I have did this many times. The pin offset is .100 Thou. With low compression pistons with out valve reliefs when u swap the piston around without taking it off the rod u need to put it in the opposite bank cause of the rod. The changer doesn’t allow it. With valve relief pistons u swap them on the rods in the same bank or u can switch from side to side. If u have floating pins like some small blocks it real simple. Just build some heat into the motor b4 u stand on it. Kim
