plastic bits in a 440
67Monaco
Punta Gorda FL
Ok, so what parts in a 440 are plastic besides timing gears? I ask because I found half a circle part in my oil pan. Looks like a guide but I can't find anything in the service manual that would point to it.
There may be nylon bushings on the distributor shaft. Are you sure it's not a mortified valve seal? Sometimes they get awful hard.
Collar on the bottom of the distributor splits and breaks.
5GQ%25GQW.f%2F1qWVs.JvV%25GQWV1sf9%25GQW%25GQFTzHTHzGHEGAcbcz%25GQ9cazbbb.%3Dgs%26gPIfm-Y%2CHzzT.jpg
Probably valve seal that turned solid. It gets so hard you can shatter it with a hammer. Otherwise there's not much for plastic in the crankcase itself aside from those parts.
Other possibility if you have after market pistons with floating pins, those have a plastic button, usually teflon, on each end of the pin. Would not expect to find those in the pan unless there is a serious problem with one of the pistons.
