Ok, I think I have it figured out, but need a little more advice.
I pulled the alternator to get it tested, just to rule it out. I took it to an old-time auto electric shop, where they owner mounted the alternator on his testing machine while I watched. "It's fine", he said.
I then told him what was going on...unregulated output at the batt terminal of the alternator, 11.9 volts at the battery, and a car full of blown bulbs.
He told me that I have a textbook example of a broken connection between the batt terminal of the alternator and the battery. "You alternator is working fine, but it has all this voltage with no place to go. It's passing through the bulkhead connector to the factory weld splice that feeds it to the lights, ignition, etc., but from there, it's not making it to the battery".
Smart guy.
He told me that I could simply run a feed from the batt terminal of the alternator to, you guessed it, the battery, with an appropriately rated fusible link. That would, of course, bypass the ammeter, but it would fix the problem.
I went back to my shop, reinstalled the alternator, disconnected the battery, and used my jump pack and a test light to check continuity of the wires leading up and away from the factory ammeter.
Alternator to engine side bulk head connector - check
Interior side bulk head connector - check
Power wire to the ammeter - check
Output terminal of the ammeter - NOTHING
Output terminal on the engine side of the bulkhead connector - check
Current through the fusible link to the starter relay - check.
SO...it appears as if I have a bad ammeter, ALTHOUGH I have seen the ammeter work SOMETIMES.
I know that the ammeter is a weak point in all early Chryslers, and there's typically problems with the shunt between the terminals.
I'd like to keep the factory ammeter if I can.
Am I better off just bypassing the ammeter and installing an aftermarket one?
Is there a way to fix the ammeter?
Any other advice before I tear the instrument cluster out?
Thank you.
Chris
