Johnny Turbo
Oooh I cracked a 440 block in the valley area once.
Any idea how it happened?
Yep... My own fault.Oooh
Dang no fun.Yep... My own fault.
This was 45 years ago. I forgot to drain the block on the drag car. It was a very late night, I was exhausted, and I left the car outside on the trailer. The tracks always wanted us to run straight water, so no antifreeze. The temperature dropped to the high 20's and it was just enough to crack the block.
Yeah we are definitely on the same page with that.Yeah, the more I think about, the heads are coming off. The compression check might help point to a blown head gasket which would be a whole lot better than a cracked cylinder head or block. If you look at the head gasket, the thinnest spots are between cylinders and between a cylinder and oil passages. At this point I'm hoping that it's a blown head gasket or at worse a cracked cylinder head and not your block!!
I had another thought to run by you all. Due to the snow I haven't had a chance to check.Yeah we are definitely on the same page with that.
I'll try to keep you all posted, once I get time/weather to pull it apart
Intake on a big block Mopar doesn't have coolant running through it. The small block does.I had another thought to run by you all. Due to the snow I haven't had a chance to check.
Could it be as simple as an intake gasket failure? Could that allow coolant to creep into an intake port and or pushrod/valley area and then down into the oil pan?
(Just thinking out loud)
Well that answers that. Thanks.Intake on a big block Mopar doesn't have coolant running through it. The small block does.
