C Body Bob
all the other tune up stuff was done last week...only points were done yest. that's the only damn thing I touched...It started and ran a couple of min just now and of course...DIED. im ready to put the old ones back in...lol. all vac lines are fine..i plugged the one to the air cleaner just to cover the bases.
Are you absolutely sure you haven't crossed a plug wire. Sometimes when removing the dizzy cap out of the way it is necessary to remove a couple of the wires and......sometime they don't get put back in the correct spot. I have run into this several times on big block engines cause the wires are so long & can easily get confusing. You should always check the dwell with a common meter that can read/measure it. Proper dwell setting equals longer point life & smoother running. Also make sure you have not damage the rotor button. A bent rotor will cause misfire. Its easy to do. And also like Stan said make sure wires are seated properly on the cap. Use die electric lube on the reluctor (where the points ride) . Make sure you have not stripped the small screw that holds the points. Easy to do. I" sure its something simple. I am not a fan of points. Pertronix makes a simple conversion that hides under the cap & eliminates the darn things & no one can tell.
