Go to your best tech and tell him to do it in his spare time.
He went home early no work he said. Besides you've seen my door rate I can't afford my techs time
And your customers are expected to support him...
Sorry but I disagree, if you have to drill holes in the doors you're doing something wrong. The po of my 67 did that on the left rear door and mangled the EFF out of it to the point that I may never get it right. He must have learned his lesson cuz the other doors were apart but no other extra holes drilled. Put the drill down and FOLLOW the FSM and you won't get hurt. That's my advice.Mount the regulator back in the door sans motor and make note of where the bolt holes are for the motor. Then drill three access holes thru the inner door to put the bolts thru. Then install the motor.
If you need to remove another one, drill the access holes first and remove the motor without disturbing the regulator.
There will be less bloodshed this way.
Kevin
The engineers forgot the holes. Put the holes back that they left out.
Formals have the holes. Somebody upstairs listened to downstairs.
Can't speak for any cars except the Formals I have sliced my knuckles on. They had holes.I wonder if that was a later revision Stan. It's been a while but I don't recall seeing them on my 76 Newport parts car. IIRC I had to slash some access ports in the inner door with a chisel. Or maybe Canadian production was different.
Kevin
Time shouldn't be the issue. Quality should be. When i saw how my inner door panel was butchered I couldn't believe it! Just to save a few minutes work? Really? Not to mention the butcher job didn't accomplish a thing. This is a hobby...we're not working flat rate and trying to get-r-done so we can go to the bar and compare pay stubs.Maybe time isn't an issue for you but I can assure you after you have had to swap out 2 or 3 used motors that failed in the same doors you will appreciate that the worst part of the job will be getting the door panel off. Been there done that and hoping these new Dorman/Denso motors I got will be the last time I ever have to see the inside of those particular doors.
I'm not sure where you got the idea that drilling three 1/2"ish holes equals a hatchet job but that's not what I was proposing.
Removing a window motor via FSM is a PIA period. According to Stan the factory finally came to that same realization too and made changing them on a Formal less of a PIA by making the doors with the holes for access.
You are however welcome to change your window hardware any way you see fit as am I.
Kevin
How do you propose to safely support the regulator so you do not lose a finger or break a forearm? I will be swapping all 4 of my motors out soon and would rather leave the regulators in place. The quarters are especially a PITA to R&R.
This is where I got the idea, no matter, we'll just have a gentlemen's disagreement on how to do it. All cars are not designed the same, and procedures should not be painted with a broad brush. If you pull the regulator of as an assembly, per the fsm, you lesson the chance of unloading the spring causing an accident.IIRC I had to slash some access ports in the inner door with a chisel.
Maybe they don't have a replacement yet or they just need to do the puck mod. Also, how do you know the orrientation of the motor? Motor at 12/9/6/3 o'clock or somewhere in between? Which is why i think my 67 was hacked up like that, and the spring unwound.Make a template off of the replacement motor.
