PM member "halifaxhops".
He's "Mr. Distributor" and should be able to help you.
Yes of course! Anything distributor he knows and maybe has. I have bought stuff from him and awhile ago I bought vintage new in box point condensor sets.
cbarge and others have valid points [no pun intended] on the benefits of electronic ignition. The pertronics I seriously considered at one time as it fits a points dizzy ,runs 12 volts instead of a ballast reduced 6 to 7 volts and looks stock under the hood. Many guys swear by them too especially the base model.
Dual points were configured such that the dwell was increased to about 40 degrees, for greater "coil saturation" and a hotter spark for higher rpm capabilities.
I thought it was also to prevent point float too?
I know the points are paper thin and im looking for new ones.
New wires and plugs...cap and rotor seem ok but don't look new. Maybe a cheap set from the zone for testing.Why not throw in a new set of points and condensor for less than 10 bucks and see what happens? How's the cap rotor, wires and plugs?
I see. I thought a dual point system was two coils and two sets of points each firing only 4 cylinders each so each set of points had only 4 lobes instead of 8. Thus more dwell and more time to recover from point float.
Some of the Mallory ignition systems were wired that way back in the day.
